Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > VideoKarma Classifieds
Old 01-10-2015, 01:00 PM
Biscuithead Biscuithead is offline
Trade or sell... 1953 Sylvania 172k CRT and chassis
I am a stereo/turntable guy... I picked up the guts out of a 1953 Sylvania
172k console. The former owner turned the cabinet into a wet-bar. I am only interested in the mono turntable. Is there any value or interest in the CRT, the chassis and the mono tuner?
I paid $50 for it all, and I would be very happy to break even....
Colorado
Tell me how to test the filament in the CRT and I will...
Pictures below...
Found out that the CRT is a 21EP4b
1-15-15 : Pins 1 and 12 show continuity so the heater is intact at least...
CRT can/will be sold separate from chassis...
Old 01-10-2015, 01:05 PM
More research revealed that it might be a 1952
Old 01-10-2015, 03:01 PM
It is not just the filament (though if the filament is bad then the CRT is definitely bad).
CRT cathode emission is important, you need a CRT tester or someone that has one, and is willing to lend it to you, in order to confirm CRT condition.
Reading between the scan lines since the mid 2000's.
Old 01-11-2015, 07:02 AM
I understand, I have had to hunt down a person with a CRT tester to prove out a couple of Oscilloscopes over the years...I was just taking the first step...
Old 01-11-2015, 08:51 AM
[CRT is a 21EP4B
Pics:
Old 01-11-2015, 08:53 AM
Wrong pics...
Here they are:
Old 01-12-2015, 06:14 AM
It looks like the CRT is a replacement from 1963.... from what I found online about the 21ep4b. I still can't find a pin diagram to tell me which is the filament...
Old 01-13-2015, 08:43 AM
Heater pins are 1 & 12. Each side of the locating key. The 21EP4 is a cylindrical faced CRT and rather uncommon. Stromberg-Carlson seemed to use them alot.
Old 01-15-2015, 05:56 AM
Thanks! I'll check it out and post my findings... I am thinking about diving into the chassis (mainly just for the Transformer-rectifier) ... Is there a great reason to keep the chassis and CRT together since they are not original to each other?
Old 01-15-2015, 09:44 AM
The CRT is a ten year newer replacement. I wouldn't want the original CRT. The one shown is a great replacement for a set that needs one. Most collector's understand that most sets that age, would have the CRT replaced by now, so original factory issue isn't important.
Unless someone needs the chassis, I wouldn't worry about it.
Old 01-15-2015, 05:34 PM
Right on...
I checked continuity between pin 1 and 12, and it rung out good... so that's intact at least...
Old 01-13-2015, 05:07 AM
If there really isn't any interest, I'm going dive in and cannibalize it soon...
Old 01-16-2015, 07:12 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Could you please post a pic of the chassis from the rear? I'm looking for the one I had in '66 (my very first TV), but later cannibalized. it had the dual 5U4 socket assy. mounted at a 45 degree angle atop the Power Transformer (but had a 3AG slo-blo fuse/holder in one of the socket holes...
Old 01-16-2015, 08:44 PM
That was the one piece that I wanted from this... Just the power supply tranny with the rectifiers on top... This is that chassis, but I would want that piece... any interest in the rest?
Old 01-19-2015, 01:25 PM
IIRC, the 24" chassis used two 5U4's. The chassis came with two configurations. One with the rectifier sockets, part of the transformer end bells and one with the socket assembly, mounted on top of the PT.
The one with the separate socket assembly, the newer 5U4's wouldn't fit, because the plate was punched for the old "G" bulb and the socket was sunken.
The UHF models of that set, had the UHF tuner under the chassis, so the chassis had to be removed to replace the UHF osc. tube. It was strange that the tuner used a 6J6, instead of a 6AF4. The 6J6 lasted a lot longer.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
ęCopyright 2012 VideoKarma.org, All rights reserved.
