I'd convert to LED....conversion eliminates the ballast, any starters, and about 25-40 watts of power - two 48" tubes, in soft or bright white, will use about 30-40 Watts total, instead of the 60-85(HO fluorescents....commonly used in signs) would use. Not to mention that the bulbs last a whole lot longer and run cooler.
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
