Old 11-12-2007, 06:51 AM
FoolForARadio's Avatar
FoolForARadio FoolForARadio is offline
AK Subscriber
Cute little radio...
It works but only has AM and no antenna, I guess it was designed for city life.
Old 11-12-2007, 09:29 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Its AM only and there's not a ferrite bar antenna inside? Weird.
Old 11-12-2007, 09:44 AM
...But it IS a "Superheterodyne"...Whoa !! (grin)
Old 11-12-2007, 12:35 PM
Aage's Avatar
Aage Aage is offline
Custom User
But it gets real fuzzy-looking when you put it in the case. Wonder why?
Experience is what you get when you don't get what you wanted.
Old 11-12-2007, 12:39 PM
Celt's Avatar
Peanut Head
Not tuned in good? J/K FFR. It's a cute little radio.
Old 11-13-2007, 07:26 AM
AK Subscriber
It is a 2R-21 made in 1965. That accounts for the fuzziness.
http://www.transistor.org/collection/sony/sony2.html
Is there any way to improve the reception, anything I can clean or whatever?
Old 11-13-2007, 09:25 AM
Celt's Avatar
Peanut Head
Well, the first thing to do is to verify whether it has an internal antenna or not. If it has a ferrite bar antenna and the bar is broken, it will need to be replaced. Reception with a broken antenna will be very poor. If the antenna and it's wiring is in good condition, then all it should need is simple alignment of the IF stages. Pretty easy on AM radios if you know how. Check for battery corrosion on the board too. Clean and resolder where any damage may have occured.
Old 11-13-2007, 10:12 AM
AK Subscriber
I think it does - copper wire wound around a bar of some material, positioned right above the tuning mechanism? Thanks, cg
Old 11-13-2007, 10:49 AM
Celt's Avatar
Peanut Head
Yep..that's the ferrite bar antenna. It's possible some of the caps have dried out and need to be replaced. (Forgot to mention that.) Then tweak the alignment. Should be a fairly easy and inexpensive task to perform.
