Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 03-16-2022, 10:10 AM
DavGoodlin's Avatar
Motorola Minion
Very surprised to hear 120 volt was ever used in Europe. Always knew Japan had 110vac though.
Standard service is 240 volts in UK/Europe, just like US 240, but its just 2 wires (line and neutral) and 50 Hz, not 60.
For industry and commercial use in Europe, 220/380volts was the early wye and 240/415 the present wye 3-phase voltage, which use a neutral conductor.
US has 3-phase in 2 standard wye configurations (208/120 and 480/277) Canada uses 600/347 wye instead of 480/277, as if that weren't enough.
USA, prior to WWII, used 220 three phase delta with no grounded conductor, just an equipment ground. 440 also used as a delta in larger users. I will spare the details on two-phase and 25 Hz, since it was early but appropriate for the times then.
Last, there is the 240/120 volt three phase delta, where one of the phases (usually B) is the "wild leg" and the other two, A+B are each 120 volts to neutral. This requires separate 240/120 single and 240 three-phase circuit breaker panels.
Lastly - Salute to both Nikolai Tesla and George Westinghouse, co-inventors of three-phase ac power!
-Dave G
Old 03-16-2022, 01:26 PM
kf4rca kf4rca is offline
Yes, I remember the old timers talking about 3 phase delta distribution, when I was a summer intern at SCE&G. The reason they went to wye was because, if a primary fell down, it would not blow a fuse or trip an OCR, because the earth was floating with respect to the primaries. It would just lay there and electrify the earth close by. Very unsafe.
Old 03-18-2022, 09:54 PM
Telecolor 3007's Avatar
I love old stuff
Here is a discusion about electricity: http://videokarma.org/showthread.php...06#post3240406
Yes, there where 120 Volts in Europe. 3 phase in some cases was 208 Volts.
Probably 120 Volts was of U.S.A. inspiration. And back then there wasn't a general standard. So there where 42 Hz. sometimes in stad of 50.
I wonder how good where the French color tv sets compared to the U.K. ones.
More about television then tv sets
https://telesatmedias.com/le-passage...-1er-oct-1967/
Here are some French colour tv sets (I like the "Schinder" very much): https://radio-piffret.pagesperso-orange.fr/TV.htm
In 1969 there where 135.000 color tv sets in France. In 1973 there where arleady 1.045.000 (1,045,000) versus 12.660.000 black and white. So about 1 in 10 tv sests was colour.
I wonder why France was so slow in allowing private tv station to broadcast.
Sailor Moon
Old 03-21-2022, 06:36 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Originally Posted by kf4rca View Post
Barco is really Dutch. Once worked at a station that had Barco monitors. They were 100% modular. You could change the standards just by swapping boards.
NO, BARCO is really from Belgium, with an american background!
https://www.barco.com/en/about-barco/history/timeline
I have some TV sets from them. For some reasons they were sold under COBAR!
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
