Most modern color CRT sets used a PCB on the socket and
are marked. You can also usually see at least the filament in the tube & usually the other elements. Some in-line CRT's Zenith & RCA & others have spring contacts. You can carefully remove the plastic key so you can grab them with the hooks. Dont know what they call them but use the hook type test lead ends ( not alligator) , they hold on best & dont short out. 73 Zeno LFOD ! |
Thread Tools | |
Display Modes | |
