Old 11-06-2017, 12:19 PM
Have a ? . Did you ring the fly you got from Eric H. It could be the wrong one or fil. voltage for the 1B3 is low or the 4.7K resistor in hv line is way high in value don't forget the 15 ohm resistor that's between the damper section and H. output plate section of the flyback. All the best, Tom.J
Old 11-06-2017, 12:40 PM
miniman82's Avatar
First Light: 1952-2011
I don’t think so Eric, if there were anything wrong with it then it would have failed ring test or not worked at all. Boost voltage is low as well, there’s not much bootstrapping action going on. That’s what leads me to believe it needs more B+ in the first place, but I know nothing without seeing the spec sheet. I could see this exact thing happening if a fly was fed half the voltage it should have, but again I need proof.
Evolution...
Old 11-07-2017, 01:17 PM
Maybe you have the horizontal output tube plate connected to a wrong terminal, in that the output pulses are going thru too much of the flyback coil. That would lead to lower high voltage and lower boost...
Check with an ohmmeter (with the set off) and see if you find a terminal around half the resistance than that you have the output tube plate connected to. That terminal might be the one to use. If you do change something, test fire up the set and measure the voltages to see if they are closer to correct, and check the cathode current of the output tube (and check that the tube isn't red-plating).
Old 11-08-2017, 06:48 PM
Nick,
Do you happen to have a Ram p/n that you need. My buddy has a lot of Ram fly backs.
Old 11-09-2017, 07:51 PM
Dave Tilotta's Avatar
Dave Tilotta Dave Tilotta is offline
As an FYI, here's what my catalog has.
Old 11-09-2017, 08:36 PM
miniman82's Avatar
Crist, Ram number shown in Sams is X-129.
Dave, thank you for the info. I’ll compare it to what I have in the chassis, to see if it makes sense.
Evolution...
Old 11-10-2017, 09:25 PM
Thanks Nick. Next time out we'll look for one and let you know.
Old 11-11-2017, 02:45 PM
miniman82's Avatar
Thanks!
Evolution...
Old 12-15-2017, 09:55 PM
miniman82's Avatar
Crist, any chance you found a compatible flyback? Unfortunately the Merit one I got from Eric is no good, the outermost part of the HV donut is overheating for some reason.
Evolution...
Old 12-17-2017, 09:48 PM
Nick,
No joy on the RAM part number. Can you provide the Sylvania part number?
Old 12-18-2017, 12:52 AM
I've got these 2 Admirals that are apparently close to the HVO 54. The first is new but I only see 3 terminals? No spec sheet either. Second is a pull from a mid 50's Admiral chassis 21A3Z ( Sams 275-2). You can try one or both for postage. If it fixes your problem I'd take a 10 buck donation, or not.
Old 12-21-2017, 12:28 PM
miniman82's Avatar
Kevin, PM sent!
Originally Posted by Crist Rigott View Post
Nick, no joy on the RAM part number. Can you provide the Sylvania part number?
Crist, the Sylvania number listed in Sams is 241-0042 or 241-0037 depending on the chassis. Not sure what difference it makes.
Evolution...
Old 12-21-2017, 01:00 PM
What year is that Sylvania and the chassis number? CRT type?
The Admiral fly shown is for a set with 90 degree sweep and 21AMP4!
Old 12-21-2017, 01:51 PM
I think I see your point.
Both Sylvania part numbers Nick lists cross to Fly 171, vs the Admiral 79C60-2 crosses to Fly 76, and the 79C60-5 to a Fly 77.
Lets make sure the deflection angles match before we make a donation to the USPS.
Old 12-21-2017, 02:18 PM
I recently picked up a Halolight but unfortunately it won’t make any HV and fails ring test after recap. If anyone has a Merit HVO-54, Thordarson FLY-76, Triad D-49 or other suitable replacement please let me know. Chassis is a 1-533-8.
OK, I looked up your chassis 1-533-8 in Sams 352-16, and it does appear to be a 90 degree deflection CRT. I'm sure you knew that.
I don't know why your OEM fly numbers cross to a Fly 171 in my Thordarson reference, but it could be something as simple as an extra tie-point terminal.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
ęCopyright 2012 VideoKarma.org, All rights reserved.
