Old 09-30-2017, 10:21 PM
Well, 'tis a puzzlement to me. The only thing I see near the switch (which opens B+ to the bandpass amp) is a 6800 ohm and 0.1 uF bypass. It's a wild guess, but you might check those. Also make sure the grounds on the chroma board are solid.
Everything else in the chroma section is running with chroma on or off, so it's hard to see how it could be there.
Old 09-30-2017, 10:23 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Hmm. I will investigate further...
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 09-30-2017, 10:29 PM
SwizzyMan's Avatar
I was wrong...
Old 10-02-2017, 01:56 PM
SwizzyMan's Avatar
Resistor and capacitor check fine and the grounds are all solid. I am at a loss.
Old 10-02-2017, 02:28 PM
Trying to figure out what could couple something at that frequency to the CRT.
Some straws to grasp at:
Does it change when you adjust the color killer control?
Maybe check the caps (especially .01 or larger) and other stuff in the color killer section?
Old 10-02-2017, 08:36 PM
SwizzyMan's Avatar
Killer control has no effect. All caps on the chroma board have been replaced so I dont think it is that..
Old 10-02-2017, 09:39 PM
Well, I'm stumped. I don't mean to be insulting, but have you double checked the values of the bypass capacitors? Other than that, it's time to put a scope on the CRT leads, and if you can see it, trace it back to the source.
Old 10-02-2017, 10:42 PM
SwizzyMan's Avatar
I will try that. Oh and the values are all correct. I may just try and deal with it as it won't be used all that much. I wonder if it is a problem with the fact that I am injecting a composite video source? This never showed up until I modified the set to accept composite inputs.
Old 10-02-2017, 10:45 PM
Of course, any modification is suspect, but how in the world would it come and go with the color switch?
Old 10-04-2017, 02:36 PM
SwizzyMan's Avatar
I really have no idea. At first I thought it was shielding related on the coax cable, but I have since got a properly shielded and grounded cable so It cant be that. I think I might just cut my losses and live with it.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
ęCopyright 2012 VideoKarma.org, All rights reserved.
