Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 06-12-2017, 04:20 PM
Captain Video's Avatar
Captain Video Captain Video is offline
"Color simulator"
This is my 1959 GE with the attachment of the unbeliavable "color simulator screen" that was sold here in my country between the 1950's and 70's. This is probably the most ridiculous TV accessory I have ever seen.
Old 06-12-2017, 08:41 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
I've seen a "deluxe model" that had 3 strips, blue across the top for sky, the red/orange across the middle for those Trump-like fleshtones, and green across the bottom for grass, I guess.
Old 06-13-2017, 07:49 AM
kf4rca kf4rca is offline
I remember seeing the deluxe version on a set back in the 60's at the shop where I worked in SC. Believe it was on a Silvertone 21".
Old 06-13-2017, 11:26 AM
Here's the one at the Early Television Museum
Old 06-13-2017, 12:04 PM
A hilariously cheap gimmick.
What I'd be interested in, is to see is how this performed. http://earlytelevision.org/pdf/pop_elect_10-68.pdf
http://earlytelevision.org/butterfield.html
If the effect is real, with today's cheap electronics it probably would not be hard to demodulate a color signal to RGB, re-matrix to YMC gate which one is shown each frame and re-modulate it as perceptual color 'monochrome' video. If I manage to un-bury myself in repairs, that project is high up on my "I want to build this" list......If it does work and I can build the circuit I'm thinking of, I know which set to test it on...One night about 6 years ago I dreamed my 19" monochrome Zenith Space Command was producing a color picture, unmodified (it'd be neat to see that).
Reading between the scan lines since the mid 2000's.
Old 06-13-2017, 02:47 PM
This was actually used by Pepsi or Coke to produce some color sensation on monochrome sets in a TV commercial, if I remember correctly. The problem with doing this with a TV is that you don't get a choice of flash rates (30 Hz or submultiples thereof in the US), so it's very sub-optimum. Plus, some choices of frequency would be banned today because of the possibility of triggering epileptic seizures in some people.
Old 06-15-2017, 10:27 PM
TVTim's Avatar
TVTim TVTim is offline
I remember my parents getting one of those. We didn't even use it for one day.
Old 06-20-2017, 12:56 AM
David Roper's Avatar
console lover
I thought it was 7-Up or Sprite, because, a flashing green bottle is the example I recall hearing about.
tvontheporch.com
Old 06-20-2017, 10:59 AM
You may be right. I haven't found a reference yet. In the case of Pepsi or Coke, I may be thinking of some commercials that used the Pulfrich effect to produce 3D. (One eye with a dark lens, the other with none.)
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
ęCopyright 2012 VideoKarma.org, All rights reserved.
