Old 04-09-2018, 10:41 AM
Telecolor 3007's Avatar
I love old stuff
Any one collects or uses old BIG electric apliances?
Any one collects or uses old BIG electric apliances? Like washingmachines, combo washingmachine/ladundry dryer, laundrary dryers, fridges/freezers/fridge + freezer combo, air condition.
Sailor Moon
Old 04-11-2018, 05:12 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I would use most of those things if I lived in a house. For the most part I have to use building owner-issued junk. It doesn't really bother me though, I don't have to pay to fix or replace the stuff. However, I have an old Kenmore A/C unit designed for casement windows, a newer but still decent Kenmore A/C unit in rather rough shape and a 1984 Kenmore microwave/convection oven that's used every day.
Old 04-15-2018, 01:40 PM
Sears didn't use the Kenmore name for their cooling appliances earlier.
IIRC, they used the Coldspot name until the early '70's.
Old 04-16-2018, 05:57 AM
Jon A.'s Avatar
I don't know exactly what vintage it is but it's definitely a Kenmore.
Old 04-11-2018, 05:29 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Just a big old Sunbeam toaster...
Old 04-19-2018, 10:31 AM
That toaster is actually a retro reproduction of an earlier design. The Sunbeam logo is silk-screened on.
We had two Sunbeam toasters, the self lowering "Radiant Control" model. When they got older, the toasting wasn't consistent.
Old 04-11-2018, 08:42 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Back in our old house, I had set up a 1950's kitchen in the basement, because my mom expressed a desire for a retro kitchen. Appliances were an Admiral fridge and a Roper gas stove. Both of which needed some work, but nothing major. We generally plugged in the fridge a little before thanksgiving and used it for holiday food storage until after xmas. When the whole family came over for a holiday, a second stove was almost impossible to do without. Especially with a thanksgiving turkey in the main kitchen's oven all day long, we would bake pies and casseroles in the basement. We moved about 5 years ago, but I kept the appliances. Sadly, they need much more attention now than before.
The fridge I got by putting a want ad up on craigslist, the reply was from the daughter of an old lady. The fridge was in the basement of their house, and it looked like it was probably used sometimes. I think I paid $40 for it, and the lady tried to sell me a Sunbeam mixer for $70, I was like lolno. The fridge always cooled very well (good old R12 system), but now it needs a door gasket ($200 from the antiqueappliances.com - the only people who still manufacture it) and as long as I've had it, it was missing a little electric heater that sat in the condensate pan and evaporated it, so if I run the fridge it just constantly drips water. Ideally I'd like to dismantle it entirely, sand blast, and repaint, because the paint looks terrible up close. Oh yeah, interestingly, it has two unique features, 1. it has a 'Magic Ray Lamp' inside (a little UV light bulb) apparently to kill bacteria and make ozone to stop flavors of uncovered foods from mixing, and 2. it has a glow-in-the-dark radium door handle INSIDE so little Timmy doesn't get trapped inside while playing hide and seek.
The stove I got from a for sale ad on craigslist. The poster was in charge of demolishing a ~1950s ranch house - no idea why, it looked fine. The stove was still hooked up in the kitchen of the house, which looked entirely original. Yellow countertops, floral pattern wallpaper, crappy linoleum, the works. I wound up taking a section of base cabinet and a bunch of chrome handles from that kitchen as well. I can still use the stove, in fact, it's one hell of a performer. Not like these modern stoves, where each burner is a little smaller than the next. All 4 burners are approx. 4 inch diameter, and each one is a double burner. One outer ring, and another inner ring, that's a lot of fire! Has great control over it too, turning the knob from 0-50% only operates the little inner ring, 50-100% turns the inner ring down a lot and lights the outer ring, as you turn it up, it turns up both. I swear it could boil a pot of water in half the time as our modern stove.
Sadly, the top deck or panel or whatever you call it, has two rust holes on either side. A common problem with Ropers apparently, it's because the pilot light heat is directed straight to the either edge of the deck. As it's porcelain enamel, I'd have to repair the rust holes entirely in steel (no bondo or brazing [not that I like brazing]) and send it out to be re-enameled, about $500. And I'd like to delete the problem-causing pilot lights, and replace with electric ignition. For the purists out there, not only do the pilot lights cause rust holes, they always took too long to light the burners as well. I stripped a junk stove of it's electrics not long ago, so I have the stuff for retrofit, just not the time.
And then there's that Kenmore wringer washer. I was maybe 14 or so, walking to school, which I went out the back of the house, through the alley, and a couple houses down there was this washing machine next to the garbage cans. I looked at it, there was nothing crucially wrong with it, so I wheeled it to my back yard, and it's been in my care ever since. It's been ages since I plugged it in, but I recall that it did run. Still, it's going to need the whole restoration. On the bright side, the porcelain is perfect, and the rest of it is just paint, so it just needs a couple dents banged out and a respray. Now if only I can cajole this one guy I know to part with his washer's timer cover and knob...
Old 04-15-2018, 07:11 PM
Celt's Avatar
Peanut Head
Friends of mine had a Hotpoint fridge and a Coldspot range/oven combo.
Old 04-15-2018, 07:45 PM
Wasn't there a Daffy Duck cartoon where he had to deal with a Possessed lady and the stove was full of ice and the freezer was full of flame?...Your post sounds like a tamer version of that joke.
Old 04-16-2018, 01:31 AM
ppppenguin's Avatar
There's a small shop near me that sells and repairs electrical appliances, something increasingly rare on the high street in the UK. In their shop they have a Hoover "Keymatic" washing machine. https://commons.wikimedia.org/wiki/F...nes_museum.JPG
These machines were found in trendy homes in the 1970s and looked like no other washing machine before or since. The programme was selected by inserting a "keyplate" https://www.flickr.com/photos/cheste...7601120083935/ The keyplate mechanism was not reliable. A gimmick really.
Old 04-16-2018, 09:43 PM
MadMan's Avatar
The Resident Brony
Well that's COOL. It's like a punchcard system for your washing machine! I can see why it would be impractical. Definitely a gimmick (punchcards in the era of early computing), but I don't see why it would be inherently unreliable. Maybe just a poor design.
Old 04-17-2018, 12:50 AM
ppppenguin's Avatar
I think the Keymatic was too complicated for its own good. Washing machine is also a fairly hostile environment with moist air and lots of vibration. Combine that with engineering down to a price and you've got problems.
Old 05-10-2018, 12:48 PM
DavGoodlin's Avatar
Motorola Minion
I understand that in the UK, you "hoover up" the floor, rather than vacuum
-Dave G
Old 05-11-2018, 01:37 AM
ppppenguin's Avatar
Yes, in the UK the brand name "Hoover" has come into general use, not only as a noun but also as a verb. And it's nothing to do with J Edgar
You see people referring to Dyson hoovers etc.
The Hoover company has effectively lost its brand name rights here.
It happens to other brands too. Scotch Tape (US) or Sellotape (UK); Kleenex (mainly US); Durex (different usages in US and UK but this is a family friendly forum) and probably many more.
https://en.wikipedia.org/wiki/Generic_trademark
Old 04-18-2018, 09:52 AM
I love old stuff
Here is another washing machine that haves a card (it's not mine): https://www.youtube.com/watch?v=NWICPMVuylg
It's not mine, but what do you see here? https://www.youtube.com/watch?v=X07Vokx8n8g&t=33s
Sailor Moon
