Brass wall plate connectors
Has anyone ever seen these before? They have been kicking around in my stuff for years. I have never seen anything similar. Some chemical cleaning brassed them up but good. "A/G" is easy. "Radio" appears to be a remote speaker connection. I am not likely to be digging in to the plaster walls here to mount them.
Somewhere around here I have a 4-tube AM that also fits in a wall plate. Somewhere.
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. Last edited by Dave A; 08-28-2018 at 11:00 PM. |
There were various radio wall plates in the 20's-40's One I got to see connected to its original radio was a single power outlet plate with A/G terminals on it.
I saw one of these recently in an elderly lady’s living room. It was next to the fireplace and had several coats of paint on it. Would’ve been interesting to see if the A/G terminals were still hooked up, and where those wires went.
Pretty damn cool. Never seen the like before. They look like they were real luxury items back in their day. Solid brass plates AND the house was wired for radio antenna? Hi tech expensive stuff.
Is the radio one a 1/4" headphone jack? If the family was listening to the radio in the living room and you were being antisocial, you could plug in your headphones in your bedroom or whatever, I'm assuming. |
If you look at the back of the plate you’ll see that the tip shorts itself to the sleeve when there’s no plug inserted. No doubt this was for protection of the house against lightning strikes. |
Audiokarma |
plug of a certain Marconi 702 might have plugged into that one. Gutta-percra coax insulation! |
Eh.... they look like standard North American wall plates. Like the distance between the mounting screws, etc, etc.
Back from med stuff. Both connection plates are insulated from the frame. No ground to the house. They are mounted insulating discs. The "Radio" is a TS 1/4" standard connector.
I can see this radio panel as a series connector going from the radio speaker output from room to room and ending at the original speaker to be interrupted at any chosen room...if you were rich enough. Apparently my grandparents did not have the glory of these plates in their mansion. Just a Radiola IV (which I have minus a few parts). Attached is a scan of a newspaper article my brother found in the Rockford archives (low res). Barney Thompson, the writer was a friend of the family. And when I was delivering the same paper on my paper route Barney was still writing his column 40 years later. I am officially old.
I suspect that the 1/4" phone plug version is just another version for an antenna/ground outlet, where the other one pictured takes pin plugs.
Dave - Great story, That infernal "A" battery dilemma - A is for Auto and Attached in your G-pops case. A 6-volt auto battery probably was a bit higher, would have required that Radiola IV to have its rheostats cranked back..
Here is another radio antenna outlet circa mid-30's https://www.quora.com/What-kind-of-e...outlet-is-this
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 03-01-2018 at 11:00 AM. |
Audiokarma |
Thread Tools | |
Display Modes | |
