Old 11-09-2017, 11:18 PM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
1993 buick lesabre radio weirdness
When i have the balance in the middle, only comes out of the left side and when the balance is turned to extreme right and volume turned up some, sound comes out of both sides equally but the right side crackles and hisses while the volume is down.
Your good times will bring me down
Old 11-09-2017, 11:30 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Never seen that. Maybe the pot for balance is just dirty/broken. Those old radios aren't particularly hard to disassemble, but you may have to just desolder the pot and actually open it to inspect/clean it.
Also... I don't know if any of those Buicks ever had an optional amplifier, but be certain it doesn't have one, as that may be your problem area.
I did have a similar GM radio in a chevy van once that only received a morse code signal, for the letters KM over and over again.
Old 11-10-2017, 02:25 AM
Where were you located at the time? The only navigation aids that use "KM" code as an identifier are not in the US.
http://worldaerodata.com/wad.cgi?search=km&apt_nv=
Old 11-11-2017, 12:15 AM
MadMan's Avatar
The Resident Brony
Chicago, lol? Why would navigation aids be using morse code identifiers broadcast as sound beeps in analog radio?
Old 11-11-2017, 01:02 AM
For easy identification... The 2 and 3 letter code id is related to the airport name...
http://www.dxinfocentre.com/ndb.htm
It is possible that these low frequency signals might be picked up by the if amp in AM radios, particularly auto radios that often have an if frequency in the 200 to 300 khz range instead of the more common 455 khz.
Note: 262.5 khz is apparently common auto radio if
Old 11-10-2017, 04:57 PM
LADR's Avatar
Местное и дх радио
That might be the case.
Old 11-11-2017, 10:27 AM
Just hit the auto salvage yards and save yourself the trouble.
If you remove it yourself, you can get if for $20 or less.
Old 11-20-2017, 05:38 PM
KM beacon listed as in Kem, Russia 0n 445 so me thinks you
got a letter wrong.
Old 11-20-2017, 11:45 PM
MadMan's Avatar
The Resident Brony
KM beacon listed as in Kem, Russia 0n 445 so me thinks you got a letter wrong.
I mean maybe, but it was only two letters, over and over. Pretty hard to screw up.
Old 11-10-2017, 08:19 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Old 11-28-2017, 05:48 AM
Dude111 Dude111 is offline
Analogue is Awesome
Originally Posted by Ed in Tx
If it's like other Delco radios of that vintage, bad electrolytic caps. I've had to replace caps in two of those I own.
Hmmmm,it may be the knob is on wrong (Not posistioned right on its pedestal or things are dirty)
I hope he can fix it easily.......
Old 11-28-2017, 07:29 AM
Ed in Tx's Avatar
I'm trying to figure out how you quoted a post that I deleted last week.
Old 11-28-2017, 10:21 PM
MadMan's Avatar
The Resident Brony
Obviously, he used Hax™.
Old 11-29-2017, 10:13 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Why do you delete your posts?
rant...
Some people... I don't understand it, something that's relevant and not necessarily bad(obscene),... and they delete it. Then when someone on google stumbles into the thread they don't understand what's going on because a member deleted all of there posts and it made the thread useless and a huge waste of time. Don't do this!
Hmm, I agree with the others that maybe you should take it apart and see if that control is bad.
I'm thinkin about pulling the original radio from my Grand Wagoneer and taking it apart. I don't listen to the radio much (Because I just love the "music" from that AMC 360) but when I do, it is very annoying for the sound to just cut out while its on. In my case it's probably a bad solder joint or a intermittent part in the amp. It does the exact same thing when playing a cassette or the radio.
Old 11-30-2017, 08:05 AM
Ed in Tx's Avatar
rant...
I offered some technical assistance based on repair experience I have had with these radios with the electronic volume control circuitry. I even posted a picture of the service manual asking if the radio in question was one of the ones in the manual. It was up over two weeks with zero response. Thread went off in a different direction, and I don't want someone stumbling on this thread a few years from now asking for a copy of the manual. I may not remember where it is by then! When you're pushing 70 years old things can get lost. I don't think I have made this thread "useless". This thread will be fine for those participating in it. I hope that answers your question.
